Topic "Dual Remote Windows with drag and drop"
clyfton
I am a SysAdmin who manages numerous Linux boxes from a Windows box. I have been searching for a tool that will work like Windows File Manager but the view would be into the remote box. A similar capability already exists in WinSCP...I can drag and drop Windows files to WinSCP and visa-versa, but I'd like to drag and drop within the Linux box. Ideally, I could configure WinSCP to show the remote box on both the left and right sides. This would be a tremendous help to me allowing me to avoid all the copy commands I do on the Linux boxes. EnginSite DataFreeway comes close but it doesn't allow internal dragging and dropping (I can configure it to show folders on the left but I can't drag and drop to/from them). I would think all the pieces are there in WinSCP, and maybe even the feature is there and I can't find it. If not, if you know of a tool that does what I'm describing, or think this is a worthy feature please let me know.
You can drag the file(s) from remote file list to remote directory tree.
clyfton
Thanks...that hit the spot. I wasn't aware WinSCP had a directory tree view.
