Topic "Truncate: File too large Error"
Dave
When I try to upload some files to my web server I get the following error:
scp: /home/httpd/docs/menu.htm: truncate: File too large
This error seems to be independent of the actual file size, one of the files that I get the error on is only 540 bytes in size, others are up to 435 Kbytes.
The contents of my log for the attempts are:
. WinSCP Version 3.3.0 (Build 177)
. Login time: Friday, 10 October 2003 12:29:25 PM
. Session name: admin@www.spca.org.au
. Host name: www.spca.org.au (Port: 22)
. User name: admin (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. SSH protocol version: 2; Compression: Yes
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: D:\spcaweb-new, Remote directory: /home/httpd/docs, Update: No, Cache: Yes
. Looking up host "www.spca.org.au"
. Connecting to 210.50.193.67 port 22
. Server version: SSH-1.99-OpenSSH_3.0.2p1
. We believe remote version has SSH2 RSA padding bug
. We claim version: SSH-2.0-WinSCP-release-3.3.0.177
. Host key fingerprint is:
. ssh-dss 1024 ff:97:06:23:7a:51:97:a5:41:72:d1:24:5b:6e:d5:98
. Initialised zlib (RFC1950) compression
. Initialised zlib (RFC1950) decompression
! Using username "admin".
. Keyboard-interactive authentication refused
. Sent password
! Access denied
. Access denied
. Sent password
. Access granted
. Opened channel for session
. Primary command failed; attempting fallback
. Started a shell/command
. Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< admin web
. Following groups found:
. admin
. web
. Changing directory to "/home/httpd/docs".
> cd "/home/httpd/docs" ; echo "WinSCP: this is end-of-file:$?"
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /home/httpd/docs
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$?"
< total 108
< drwxr-xr-x 8 admin admin 4096 Oct 10 02:07 .
< drwxr-xr-x 5 admin admin 4096 Jun 19 2002 ..
< drwxr-xr-x 2 admin admin 4096 Oct 10 03:04 SPCA
< -rw-r--r-- 1 admin admin 4618 Oct 6 13:48 aboutus.htm
< -rw-r--r-- 1 admin admin 2193 Oct 6 13:48 branches.htm
< -rw-r--r-- 1 admin admin 2228 Oct 6 13:49 dads_on_the_air.php3
< drwxr-xr-x 2 admin admin 4096 Oct 10 01:30 document_library
< drwxr-xr-x 6 admin admin 4096 Oct 7 13:57 forms
< drwxr-xr-x 2 admin admin 4096 Oct 6 14:16 images
< -rw-r--r-- 1 admin admin 479 Oct 6 14:03 index.htm
< -rw-r--r-- 1 admin admin 8080 Oct 6 14:04 index_wait.htm
< -rw-r--r-- 1 admin admin 7910 Oct 6 13:49 join.htm
< -rw-r--r-- 1 admin admin 12648 Oct 6 13:49 library.htm
< -rw-r--r-- 1 admin admin 4893 Oct 6 13:49 main.php3
< -rw-r--r-- 1 admin admin 3447 Oct 6 13:49 media.htm
< drwxr-xr-x 2 admin admin 4096 Oct 6 13:45 media_news
< -rwxr-xr-x 1 admin admin 2563 Oct 10 02:50 menu.htm
< -rw-r--r-- 1 admin admin 2251 Oct 6 13:47 spca.css
< -rw-r--r-- 1 admin admin 540 Oct 10 02:48 spca_menu.css
< drwxr-xr-x 2 admin admin 4096 Oct 10 02:03 test
. Startup conversation with host finished.
. Copying 1 files/directories to remote directory "/home/httpd/docs/"
. PrTime: Yes; PrRO: Yes; Rght: rwxr-xr-x; PrR: Yes; FnCs: N; RIC: Yes; Resume: S (10240)
. TM: M; AscM: *.*htm*; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
> echo "WinSCP: this is begin-of-file" ; scp -r -p -d -t "/home/httpd/docs" ; echo "WinSCP: this is end-of-file:$?"
< WinSCP: this is begin-of-file
. SCP remote side confirmation (0)
. Asking user:
. File 'menu.htm' already exists. Overwrite? ()
. File: "D:\spcaweb-new\menu.htm"
. Copying "D:\spcaweb-new\menu.htm" to remote directory started.
. Ascii transfer mode selected.
> T1065751038 0 1065751047 0
> C0755 2563 menu.htm
. Sending ASCII data (2563d bytes)
. Sending NULL.
< scp: /home/httpd/docs/menu.htm: truncate: File too large
. SCP remote side error (1):
. Asking user:
. Copying file "D:\spcaweb-new\menu.htm" failed. ("scp: /home/httpd/docs/menu.htm: truncate: File too large")
* (EScpFileSkipped) scp: /home/httpd/docs/menu.htm: truncate: File too large
> E
* (ETerminal) Command failed with return code 1.
Question
Yours,
Dave McLachlan
Canberra,
Australia
I have never seen this error before. Does it happen with all files? Can you try to upload same files another client (like PSCP)?
Dave
Martin,
It happened with all files through WinSCP, I didn't have any other SCP client installed at the time but I used CoffeeCupFTP to successfully upload the files. I will try again and see if I get the same errors with PuTTY. I tried PSCP and got the following errors:
--Start of Output--
C:\>pscp.exe -load spca -v -pw ######## "d:\spcaweb-new\spca.css" admin@www.spca
.org.au:/home/httpd/docs/test/spca.css
We claim version: SSH-1.5-PuTTY-Release-0.53b
Using SSH protocol version 1
Received public keys
1024 7a:4d:52:af:8f:35:c7:48:13:3f:c0:6f:d0:88:9e:3d
Encrypted session key
AES not supported in SSH1, skipping
Using Blowfish encryption
Trying to enable encryption...
Successfully started encryption
Sent username "admin"
Sending password with camouflage packets
Sent password
Authentication successful
Started session
Connected to spca.org.au
Sending file spca.css, size=2385
scp: /home/httpd/docs/test/spca.css: Permission denied
Sent EOF message
Server sent command exit status 1
--End of Output--
There are no permission problems for the directory as I have successfully logged in to the server using FTP and the same usename and transferred the file to the directory.
I'll keep fidlling around to see if it is some congiguration issue with my system or the host server.
Yours,
Dave McLachlan
Canberra,
Australia
If you find anything new, please post it here. I'm interested to know, if it is problem on WinSCP side or on your server side. Anyway, you may consider trying SFTP instead of SCP.
