Topic "Bad file copy"
deepthinker
WinSCP ver 4.1.8 (the latest !)
I have a file here which is 24,232 bytes long but despite copying from Windows-XP to my Linux machine in BINARY mode the copy is corrupt and only 24,231 bytes in length. This is repeatable. Help !
deepthinker
Thanks. The log shows ASCII file transfer, even though BINARY was selected in Transfer Settings in the Copy pop-up box.
I have changed the defaults so that all files are sent in binary.
Is it a bug that setting Binary (or anything else) in Transfer Settings does not override the defaults ?
How do you upload the file?
deepthinker
1. Select the file to be copied on the left-hand panel
2. Press the F5 key
3. In Transfer Settings, select Binary
Adrian
I'll send you a debug version soon.
