Topic "Vista - import settings from WinXP to Vista - not working"
scanreg
On WinXP box, exported settings to WinSCP.ini
Then, copied them into the new WinSCP program directory on my new Vista machine:
\Program Files\WinSCP\WinSCP.ini
However, when I restart WinSCP on the Vista machine, those imported settings are not recognized.
I read the documentation but I'm wondering if Vista is making things more complicated
Any help most appreciated, thanks
Are you sure you run WinSCP from that directory?
If you go to preferences, is INI file selected?
If not, close WinSCP, remove the INI file, start WinSCP, go to preferences, select INI file, close WinSCP. Check if the INI file was created.
If not, start WinSCP, go to preferences and see if the setting was preserved. If it was not, WinSCP do not have a permission to write to the directory. If it was, WinSCP created file elsewhere, because it is actually run from elsewhere.
scanreg
Hi
Yes, it runs from "C:\Program Files\WinSCP\WinSCP.exe" (according to the shortcut on the desktop)
Yes, INI is selected
I tried that, went to preferences, selected INI, closed WinSCP, then re-opened, but no INI file was created - however, the previous Session had been saved (as desired) - apparently it is saving only in the registry, even though INI is selected
Yes, the INI setting was preserved
Where else could it be running from? I don't have a clue where else to look (besides in the Program Files directory)
Thanks Smile
If INI file is selected even after WinSCP restart, then INI file must exist. The selection is not stored anywhere. It is dynamically determined on WinSCP start, based on presence of the INI file in EXE directory. So if there's no C:\Program Files\WinSCP\WinSCP.ini, then you are not starting C:\Program Files\WinSCP\WinSCP.exe.
Maybe it is some feature of Vista. It may copy the EXE to some temporary directory, where it starts it from?? I do not know. If you do not manage to resolve this, come back, I'll send you a debug version to track this down. Even if you manage to resolve this, let me know what was it.
ival
You should run as administrator the exe file so it can read the .ini file in the exe directory.
Telepath
Maybe its dedicated feature to deselect boons... Wink
SCNR either... Wink Wink
Freitag
Vista does not allow non-Admin users to change files under C:/Program Files directory.
You can change the default location of the .ini file by editing your shortstop that you use to start WinSCP
Look here for help: http://winscp.net/eng/docs/commandline
Ricardo
C:\Users\<User>\AppData\Local\VirtualStore\Program Files\WinSCP\WinSCP.ini
Telepath
Still not best choice install all progs under $system_directory btw...
Try to have your system as clean as u can do.
Install "user driven" apps in other partition and/or phys/logical drives.
So you have "clean" system if critical error occures...
It surely does, depending on file/folder permissions admin set.
Vista security is more powerful than u may think... Wink
btw: suggest "Total Commander" from www.ghisler.com as preferred
file manager for all Win-Versions.
WinSCP of course is way better than all there inbuild "ftp's", but:
Explorer is fu***ng bullshit imho... Wink
And, at least me reporting:
Works fine with no errors at all under Win 7(final, system builder) Ultimate 64 bit.
Thx to prikryl Very Happy
