Topic "Winscp.exe - Abnormal program termination"
FHuge
I am using WINSCP version 4.1.8, (build 415) and a script file with commands.
When transferring a file which size exceeds the file size limit set on the destination machine, winscp.com aborts automatically after 15 seconds. This can be seen in the logfile. But after this event a popup message is shown, which states Abnormal program termination. In the caption of this message box is Winscp.exe
I use winscp in batch mode, but due to this message winscp will hang up.
Winscp processes (winscp.exe and winscp.com) stay active in Windows taskmanager.
Can you try the same with 4.2.1? Thanks.
I tried 4.2.1, but same problem..
Will send you a debug version soon.
