Topic "Error Directory listing on Vista"
KHANSAHAB
I am trying to connect SFTP on vista version 3.x.x - 4.x.x after connection it gives
Error Directory listing /home/a/alikhan server didn't respond within 15 seconds.
I turned off firewall but it's not showing any thing.
It's working on XP but i m not using it right now.
Kindly Help me
