Topic "Windows reports WinSCP as "Not Responding" very frequently"
NiteShdw
I use WinSCP to connect to several FTP sites. At some point while I'm online WinSCP will always show up as "Not Responding."
I believe the issue has to do with the FTP connection being unexpectedly disconnected. I occasionally get a Reconnect dialog, but most of the time, WinSCP just grays out and I have to close it down.
Just to be clear, this happens EVERY time I use WinSCP. The only reason I continue using WinSCP is that I can't find another freeware FTP program that has all the great features of WinSCP.
I can't tell you how incredibly frustrating it is to have WinSCP constantly freezing up and being forced to restart it.
I believe that this problem has been fixed already.
But anyway, can you send me an email, so I can send you back the latest development version to make sure? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
NiteShdw
I see that I'm currently running 4.1.8. It was the latest version the last that I checked.
I'll download the 4.2.1 beta.
The fix is not released yet. It will be part of 4.2.2 and possibly 4.1.9.
If you sent me an email I can send you development to make sure the fix solves your problem.
