Topic "Can not connect to AIX with WINSCP 4.0.0 and Privatekey"
swissbusinet
Hello all!
I'm nubie with WinSCP.
I tried to script a simple fetch with wildcard.
I have the version 4.0.0 and I could not update (all downlaods blocked by the security)
This works to open the console:
winscp.exe /console /open sftp://user22@host21.mybank.ch -privatekey=RSA.key.ppk /script scp_kript.scp
This don't work
winscp.exe /console /command "open sftp://user22@host21.mybank.ch -privatekey=RSA.key.ppk" "ls"
I tried many variants. Including Skript file.
My question is how to add commands.
The task I'm on is to change from passwd auth to pub/privat key.
The old command which works over years:
pscp -l user22 -pw xxx -q host21:mydir/%rep%*.CSV %basefiles%
(%rep% and %basefile% are win batch vars)
Who could help?
There's no /open command line parameter. It is simply ignored.
Quote:
This don't work
This is correct. Though -privatekey switch to open command (as opposite to command line parameter /privatekey) has been introduced in 4.1 only. Please upgrade.
