Topic "problem with winSCP.FR"
Marc73
hello.
On my newly installed windows 7, when I installed winSCP,and chose to install in FRENCH, I got the error that the winSCP.FR is NOT configured to work with THIS version of the software (though it is indeed, and it is the version that comes with the default installer)
I downloaded a fresh copy of the FRENCH translation, the winSCP.FR, and replaced the old file. did not solve the problem.
I tried re-installing a fresh copy of the default soft, still this did not solve the issue.
What version of WinSCP have you installed? When did you get the error message first time? Yet during installation? For what version did the message claim the .fr file to be?
Marc73
man am sorry my message was not clear enough.
I downloaded and installed the last stable release...... 4.19
http://puzzle.dl.sourceforge.net/sourceforge/winscp/winscp419setup.exe
Can you answer my other questions as well?
Marc73
I would be thankful to you prikryl if you would kindly use two alternative colors for successive posts...... it is really not so obvious where your post starts and where mine ends.
I got the error related to the french file on first-run, nothing I remember during setup. the message did not give any specific information about version differences other than a generic message saying that the winscp.fr file is not the right version.
voil
salnet
I ran into the same problem, described in topic 6852.
I've sent debug version to both of you.
dan
I also have the same problem.
can you send me the debug version too.
thks
I have the same problem trying to use the german version. Is there any solution available?
As you can see in the tracker, this was resolved in 4.2.2.
