Topic "Log ls listing to TEXT/ASCII file NOT XML"
rec9140
I would love to see a way to do:
ls > remotedir.txt
So that the directory listing is saved to a file, remotedir.txt
/log and XML are no good.
/log just adds it to the log with other stuff, I don't need.
XML, don't use it, don't like it, don't want it.
This would make it a simple task to email via sendmail or other function, the ls output for other tasks to users with out adding a XML decoding layer and processing.
Thanks.
Sorry, I'm not going to introduce duplicate functionality, just because you do not like XML...
See guide to advanced scripting to learn how to easily extract directory listing from XML log.
rec9140
I don't see XML being a plus when a listing in plain ASCII with CR/LF would be x file equals x lines in the files.
12345.pdf
1231231.pdf
123123.pdf
1246496.pdf
Where as XML has extra wasted noise for <fksddfslfj> <aakjka> All that could have been a file name.
Thanks, but my scripting language doesn't handle XML. ASCII no problem.
