Topic "sync between Win and Linux"
Hi, I setup a script to use winscp.exe to sync my win files to a backup them up to my Linux box. I test the script on few files and directories and it works. but then I added all of my Directories it hangs at a certain Dirctories and return a error "Host is not Communication for more than 15 second, Abort, Terminated by user, Error listing Directory, No session". I upgraded from 4.0 to 4.2 still the same issue. used Passive option in the open command but still same issue.
here is my script
# Automatically answer all prompts negatively not to stall the script on errors
option batch on
# Connect using a password
# open
# Change remote directory
cd /web/mydoc/
# Force binary mode transfer
option transfer binary
# Download file to the local directory
# synchronizing DIRECTORIES
synchronize remote D:\MyDocuments\Appxxxx /web/mydocxxx/Appxxxx
synchronize remote D:\MyDocuments\docxxxx /web/mydoc/docxxx
Please post a full log file showing the problem (with the latest version)
