Topic "Bug ? No override confirmation on scripting with option on"
I'am using WinSCP (version 4.1.9 after a try with 4.1.7) on Windows Vista 32, in scripting mode.
I use put command to upload a file to the server and wait for a overwrite confirmation because the file already exists on it. But there is no confirmation although i have enable option confirm on. I have also tried with option batch off, or batch abort but there is no confirmation again.
The only confirmation i can produce is when a partially uploaded file exists on the server.
Is there a bug with the option confirm on ? Can someone help me please ?
Thanks a lot
winscp> open
Recherche de l''hte...
Session active : [1]
winscp> option
echo         off
batch        off
confirm      on
transfer     automatic
winscp> option batch on
batch        on
winscp> option confirm on
confirm      on
winscp> option echo on
echo         on
winscp> option
echo         on
batch        on
confirm      on
transfer     automatic
winscp> put
put                 |        663 KiB |  147,3 KiB/s | binary | 100%
winscp> put
put                 |        663 KiB |  162,0 KiB/s | binary | 100%
winscp> exit
Have tried to uninstall/reinstall properly on vista but no changes... very strange i assume it's a bug to add to the Tracker... ?
