Topic "Unclear passworddialog connecting ssh tunneled through ssh"
holger.jeromin
If connecting a ssh tunneld through a ssh server it is not easy to say what password winscp is asking for. The Windowtitle does not change and is for the host, not for the tunnel-host.
Would be nice, if the name of the tunnel-host would be mentioned somewhere in the dialog. for example:
Password for tunnel-host (user@tunnel):
and than after the next connection:
Password for host (user@server):
Thanks a lot.
Holger
I believe WinSCP does that. What version of WinSCP are you using? Have you tried the latest one? If you use that, can you post a screenshot? Or at least log file.
holger.jeromin
I tested with WinSCP 4.2.1 beta
Still no hint to the name of the tunnelhost.
my loginname is identical in my hosts, so it is not clear, with host i used for the tunnel Smile
What about the:
Quote:
Tunnel session authentication
holger.jeromin
prikryl wrote:
What about the:
Thanks for your quick reply.
my loginname is identical in my hosts, so it is not clear, with host i used for the tunnel. I dont say the dialog is wrong, but it could be better Smile
holger
