Topic "goes to 99% and times out"
gemal
I'm using synchronize and my large file transfers seems to go fine up until 99% and then it just hangs. it then hangs in a periode that's equal to the timeout.
After the timeout winscp tried to reconnect and then it does the same thing again.
Small files seems to work just fine.
I'm using:
open ftp://user:pass@host:21 -timeout=3600
synchronize remote c:\backup\ /backup/ -speed=200 -delete -criteria=size
. 2009-06-02 09:38:59.208 --------------------------------------------------------------------------
. 2009-06-02 09:38:59.208 WinSCP Version 4.1.9 (Build 416) (OS 5.2.3790 Service Pack 2)
. 2009-06-02 09:38:59.208 Login time: 2. juni 2009 09:38:59
. 2009-06-02 09:38:59.208 Session name: BLABLA
. 2009-06-02 09:38:59.208 Host name: BLABLA (Port: 21)
. 2009-06-02 09:38:59.208 User name: BLABLA (Password: Yes, Key file: No)
. 2009-06-02 09:38:59.208 Tunnel: No
. 2009-06-02 09:38:59.208 Transfer Protocol: FTP
. 2009-06-02 09:38:59.208 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2009-06-02 09:38:59.208 Proxy: none
. 2009-06-02 09:38:59.208 FTP: Passive: No
. 2009-06-02 09:38:59.208 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-06-02 09:38:59.208 Cache directory changes: Yes, Permanent: Yes
. 2009-06-02 09:38:59.208 DST mode: 1
. 2009-06-02 09:38:59.218 Connecting to BLABLA ...
. 2009-06-02 09:38:59.228 Connected with BLABLA. Waiting for welcome message...
< 2009-06-02 09:39:09.354 220 192.168.1.5 FTP server ready
> 2009-06-02 09:39:09.354 USER BLABLA
< 2009-06-02 09:39:09.414 331 Password required for BLABLA.
> 2009-06-02 09:39:09.414 PASS **********
< 2009-06-02 09:39:09.514 230 User BLABLA logged in.
> 2009-06-02 09:39:09.514 SYST
< 2009-06-02 09:39:09.554 215 UNIX Type: L8
> 2009-06-02 09:39:09.554 FEAT
< 2009-06-02 09:39:09.594 211-Features:
< 2009-06-02 09:39:09.594  MDTM
< 2009-06-02 09:39:09.594  REST STREAM
< 2009-06-02 09:39:09.594  SIZE
< 2009-06-02 09:39:09.594 211 End
. 2009-06-02 09:39:09.604 Connected
. 2009-06-02 09:39:09.604 --------------------------------------------------------------------------
. 2009-06-02 09:39:09.604 Using FTP protocol.
. 2009-06-02 09:39:09.604 Doing startup conversation with host.
> 2009-06-02 09:39:09.604 PWD
< 2009-06-02 09:39:09.644 257 "/" is current directory.
. 2009-06-02 09:39:09.644 Getting current directory name.
. 2009-06-02 09:39:09.644 Startup conversation with host finished.
. 2009-06-02 09:39:09.644 Collecting synchronization list for local directory 'c:\backup\' and remote directory '/array1/DBS/backup/', mode = 0, params = 1539
. 2009-06-02 09:39:09.654 Retrieving directory listing...
> 2009-06-02 09:39:09.654 CWD /array1/DBS/backup/
< 2009-06-02 09:39:09.694 250 CWD command successful
> 2009-06-02 09:39:09.694 PWD
< 2009-06-02 09:39:09.734 257 "/array1/DBS/backup" is current directory.
> 2009-06-02 09:39:09.734 TYPE A
< 2009-06-02 09:39:09.774 200 Type set to A
> 2009-06-02 09:39:09.784 PORT 87,237,213,28,17,59
< 2009-06-02 09:39:09.824 200 PORT command successful
> 2009-06-02 09:39:09.824 LIST -a
< 2009-06-02 09:39:09.904 150 Opening ASCII mode data connection for file list
< 2009-06-02 09:39:10.505 226 Transfer complete.
. 2009-06-02 09:39:10.505 Directory listing successful
. 2009-06-02 09:39:10.616 Collecting synchronization list for local directory 'c:\backup\files' and remote directory '/array1/DBS/backup/files', mode = 0, params = 1539
. 2009-06-02 09:39:10.616 Retrieving directory listing...
> 2009-06-02 09:39:10.616 CWD /array1/DBS/backup/files/
< 2009-06-02 09:39:10.656 250 CWD command successful
> 2009-06-02 09:39:10.656 PWD
< 2009-06-02 09:39:10.696 257 "/array1/DBS/backup/files" is current directory.
> 2009-06-02 09:39:10.696 TYPE A
< 2009-06-02 09:39:10.736 200 Type set to A
> 2009-06-02 09:39:10.746 PORT 87,237,213,28,17,61
< 2009-06-02 09:39:10.786 200 PORT command successful
> 2009-06-02 09:39:10.786 LIST -a
< 2009-06-02 09:39:10.866 150 Opening ASCII mode data connection for file list
< 2009-06-02 09:39:11.036 226 Transfer complete.
. 2009-06-02 09:39:11.036 Directory listing successful
. 2009-06-02 09:39:11.066 Synchronizing local directory 'c:\backup\' with remote directory '/array1/DBS/backup/', params = 1539
. 2009-06-02 09:39:11.076 Copying 64 files/directories to remote directory "/array1/DBS/backup/"
. 2009-06-02 09:39:11.076   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2009-06-02 09:39:11.076   TM: M; ClAr: No; CPS: 204800; ExclM(No):
. 2009-06-02 09:39:11.076   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-06-02 09:39:11.076 File: "c:\backup\BLABLA-01_05.sb"
. 2009-06-02 09:39:11.076 Copying "c:\backup\BLABLA-01_05.sb" to remote directory started.
. 2009-06-02 09:39:11.076 Binary transfer mode selected.
. 2009-06-02 09:39:11.076 Starting upload of c:\backup\BLABLA-01_05.sb
> 2009-06-02 09:39:11.076 CWD /array1/DBS/backup/
< 2009-06-02 09:39:11.116 250 CWD command successful
> 2009-06-02 09:39:11.116 PWD
< 2009-06-02 09:39:11.156 257 "/array1/DBS/backup" is current directory.
> 2009-06-02 09:39:11.156 TYPE A
< 2009-06-02 09:39:11.196 200 Type set to A
> 2009-06-02 09:39:11.196 PORT 87,237,213,28,17,63
< 2009-06-02 09:39:11.246 200 PORT command successful
> 2009-06-02 09:39:11.246 LIST -a
< 2009-06-02 09:39:11.327 150 Opening ASCII mode data connection for file list
< 2009-06-02 09:39:11.887 226 Transfer complete.
> 2009-06-02 09:39:11.897 TYPE I
< 2009-06-02 09:39:11.928 200 Type set to I
> 2009-06-02 09:39:11.938 PORT 87,237,213,28,17,65
< 2009-06-02 09:39:11.978 200 PORT command successful
> 2009-06-02 09:39:11.978 STOR BLABLA-01_05.sb
< 2009-06-02 09:39:12.078 150 Opening BINARY mode data connection for BLABLA-01_05.sb
. 2009-06-02 09:42:15.514 Timeout detected.
. 2009-06-02 09:42:15.514 Copying files to remote side failed.
. 2009-06-02 09:42:15.514 Connection was lost, asking what to do.
. 2009-06-02 09:42:15.514 Asking user:
. 2009-06-02 09:42:15.514 Lost connection. ("Timeout detected.","Copying files to remote side failed.","Opening BINARY mode data connection for BLABLA-01_05.sb")
[/code]
Will send you a debug version soon.
Seeing your email address, I suppose it is black hole.
gemal
I'm watching that black hole. So just send it there
I did.
