Topic "Filename Issue"
Hello Martin,
When I attempt to sync the file 4184_A229 - 049.pdf I encounter an error (see link). In the error message it looks like it does not pickup the "9" in the filename. I think this is why it is unable to find the file because it has the wrong filename.
Please note I am using WinSCP v4.2.1 on Windows 2003 x86.
Is this a bug or have a done something wrong?
Thank you,
