Topic "Proxy support needed"
jiweigert
WinSCP still does not support connections via Proxy nor Firewall.
It would be great to have an Option to configure an Proxy that will used by WinSCP (for each session and or general) to connect to remote systems and the check for updates..
Kind regards,
Joern-Ingo Weigert
Blue Pier GmbH Germany
WinSCP supports Proxy. See Proxy tab of login dialog. You have to enable "Advanced options" to see it.
jiweigert
Thanks for this quick answer.
Maybe it would be good if there are a seperate Tab in the Options to define an default proxy..
Kind regards,
Joern-Ingo Weigert
Blue Pier GmbH
PS: Great Product!
