Topic "server response timeout"
black_ps
if you set "server response timeout" if you set it at 99999 for example or something like and connect to ftp , then you exit winscp and enter again the "server response timeout" will be 15 again,is this a bug ? using 4.1.9 build 416 using Windows XP Home Edition Service Pack 2.
Where do you set it to 99999? Do you save you settings to stored session or default settings then? Or do you expect it to persist automatically?
black_ps
in the default session
http://img10.imageshack.us/img10/7744/sshot1kvo.jpg [img][/img]
What I do:
- start WinSCP
- go to Connection tab
- set Server response timeout to different value (note that maximum is 6000, so 9999 won't fit)
- go to Stored sessions tab
- click Set defaults
- confirm setting defaults
- exit WinSCP
- start WinSCP
- the value I've set before is there
Does this work for you?
black_ps
yes like this is working,thanks.
