Topic "Transfer channel can't be opened"
ArchAngelPaladin
While in passive mode, when connecting to a ftps server using explicit ssl I get the following error:
Transfer channel can't be opened. Reason: The requested name is valid, but no data of the requested type was found.
Note that Filezila and Smartftp work just fine, so firewall setting are a non-issue. In addition , winscp works on another FTPS SSL server in passive mode that we have control of but not the site in question.
Ive tried playing with the panel settings, the transfer mode settings, and some of the environmental settings, but all got no joy.
Thanks for any help.
Also for reference here is the log:
. 2009-06-10 15:57:03.339 --------------------------------------------------------------------------
. 2009-06-10 15:57:03.339 WinSCP Version 4.2.1 (Build 428) (OS 5.2.3790 Service Pack 2)
. 2009-06-10 15:57:03.339 Login time: Wednesday, June 10, 2009 3:57:03 PM
. 2009-06-10 15:57:03.339 Session name: kbb
. 2009-06-10 15:57:03.339 Host name: ftps.kbb.com (Port: 21)
. 2009-06-10 15:57:03.339 User name: dtaaxftp (Password: Yes, Key file: No)
. 2009-06-10 15:57:03.339 Tunnel: No
. 2009-06-10 15:57:03.339 Transfer Protocol: FTP
. 2009-06-10 15:57:03.339 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-06-10 15:57:03.339 Proxy: none
. 2009-06-10 15:57:03.339 FTP: FTPS: Explicit SSL; Passive: Yes
. 2009-06-10 15:57:03.339 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-06-10 15:57:03.339 Cache directory changes: Yes, Permanent: Yes
. 2009-06-10 15:57:03.339 DST mode: 1
. 2009-06-10 15:57:03.355 Connecting to ...
. 2009-06-10 15:57:03.402 Connected with , negotiating SSL connection...
< 2009-06-10 15:57:03.448 220 Welcome to FTPS
> 2009-06-10 15:57:03.448 AUTH SSL
< 2009-06-10 15:57:03.480 234 Authentication method accepted
. 2009-06-10 15:57:03.558 SSL connection established. Waiting for welcome message...
> 2009-06-10 15:57:03.558 USER
< 2009-06-10 15:57:03.605 331 User password please
> 2009-06-10 15:57:03.605 PASS
< 2009-06-10 15:57:03.730 230 Password Ok, User logged in
> 2009-06-10 15:57:03.730 SYST
< 2009-06-10 15:57:03.761 215 UNIX Type: L8
> 2009-06-10 15:57:03.761 FEAT
< 2009-06-10 15:57:03.808 211- Additional features supported include:
< 2009-06-10 15:57:03.808 MDTM
< 2009-06-10 15:57:03.808 MFCT
< 2009-06-10 15:57:03.808 MFMT
< 2009-06-10 15:57:03.808 SIZE
< 2009-06-10 15:57:03.808 REST STREAM
< 2009-06-10 15:57:03.808 AUTH TLS
< 2009-06-10 15:57:03.808 AUTH SSL
< 2009-06-10 15:57:03.808 PBSZ
< 2009-06-10 15:57:03.808 EPRT
< 2009-06-10 15:57:03.808 EPSV
< 2009-06-10 15:57:03.808 XCRC
< 2009-06-10 15:57:03.808 XSHA1
< 2009-06-10 15:57:03.808 XMD5
< 2009-06-10 15:57:03.808 PROT
< 2009-06-10 15:57:03.808 LANG EN*
< 2009-06-10 15:57:03.808 SITE CHMOD
< 2009-06-10 15:57:03.808 SITE PSWD
< 2009-06-10 15:57:03.808 SITE ZONE
< 2009-06-10 15:57:03.808 MLST Type*;Size*;Modify*;Create*;
< 2009-06-10 15:57:03.808 CLNT
< 2009-06-10 15:57:03.808 CSID
< 2009-06-10 15:57:03.808 RMDA
< 2009-06-10 15:57:03.808 UTF8
< 2009-06-10 15:57:03.808 211 End
> 2009-06-10 15:57:03.808 PBSZ 0
< 2009-06-10 15:57:03.839 200 PBSZ=0
> 2009-06-10 15:57:03.839 PROT P
< 2009-06-10 15:57:03.886 200 PROT P OK, data channel will be secured
. 2009-06-10 15:57:03.886 Connected
. 2009-06-10 15:57:03.886 --------------------------------------------------------------------------
. 2009-06-10 15:57:03.886 Using FTP protocol.
. 2009-06-10 15:57:03.886 Doing startup conversation with host.
> 2009-06-10 15:57:03.886 PWD
< 2009-06-10 15:57:03.917 257 "/" is the current directory
. 2009-06-10 15:57:03.917 Getting current directory name.
. 2009-06-10 15:57:03.917 Retrieving directory listing...
> 2009-06-10 15:57:03.917 TYPE A
< 2009-06-10 15:57:03.964 200 Type ASCII
> 2009-06-10 15:57:03.964 PASV
< 2009-06-10 15:57:03.995 227 Entering Passive Mode ( 209,67,183,26,4,27)
> 2009-06-10 15:57:03.995 LIST -a
. 2009-06-10 15:57:06.324 Transfer channel can't be opened. Reason: The requested name is valid, but no data of the requested type was found.
. 2009-06-10 15:57:06.324 Could not retrieve directory listing
. 2009-06-10 15:57:06.324 Retrieving directory listing...
> 2009-06-10 15:57:06.324 TYPE A
. 2009-06-10 15:57:21.340 Timeout detected.
. 2009-06-10 15:57:21.340 Could not retrieve directory listing
* 2009-06-10 15:57:21.340 (ESshFatal) Lost connection.
* 2009-06-10 15:57:21.340 Timeout detected.
* 2009-06-10 15:57:21.340 Could not retrieve directory listing
* 2009-06-10 15:57:21.340 Error listing directory '/'.
Please post a log file from Filezilla.
More information about "Transfer channel can't be opened" error:
http://winscp.net/eng/docs/message_transfer_channel_cant_be_opened
