Topic "FTP maybe bug "OOPS: priv_sock_send_cmd""
Sirisian
When trying to connect to a certain server using the FTP features I receive an error box that says:
I can connect to other servers fine, but this one server is different. I can connect to this server using FireFTP (The firefox plugin). I used the same exact information.
I think a possible reason is that the FTP implementation tries to open the / directory when it connects. The server I'm connecting to forces a directory redirection and connects me to a certain folder on that server not the / directory. Just a guess though. I've connected to my 1and1 account which does the same thing and it works fine though.
Using WinSCP 4.0.2
Please upgrade to the latest stable version of WinSCP and post a log file showing the problem.
