Topic "delete option after downloading file"
dindin
Its would be nice feature if WinSCP have an option to delete file after the file downloaded in WinSCP GUI Option ( I knew that WINSCP have that function from command pompt ). Delete file after download can very usefull for limited space server for (just) file exchange only.
Many thanks...
Dindin
That's what File(s) > Move command is good for.
Thanks... I'll try to use move command but i be worried about slow and bad connection that happen (sometimes).
Can you tell me how the move command works in slow or bad connection that can broken off file transfer.. Is the move command cancel / abort file transfer without file corrupt (rollback file to origin source) or will resume file.. ?
Thanks..
