Topic "transmission ends at 65536 KiB"
knutson
Hi to all,
I tried out the 4.2.1 beta release and found out that it is impossible to send files larger than 65536kB. The error- message told me that it is a timeout, but this cannot be. After uninstall that version and installing the stable 4.1.9, everything worked fine, so I think that this might be a bug.
The transmission was pure FTP.
System: WinXP MCE 2005
Receiver: external ftp-disk on a FritzBox- Router.
Hope that this was helpful.
So long
Knutson
Please post a full log file showing upload of the large files both using 4.1.9 and 4.2.1?
Lou van Wijhe
Knutson,
Was this ever resolved? If not, would it be plausible to go back to 4.1.9 (if still available)?
Lou
