Topic "An ideal situation - TotalCommander-like command line"
Andy M.
Hi.
I have a vision of adding command line to the WinSCP, just as the one used in Total Commander (I know there is actually a kind of support for command line processing, but it is implemented as a modal window, thus preventing operations such as F5-COPY or F4-EDIT). And maybe it could go a step further than Total Commander does? What about 2 or 3 lines of command line instead of just one?
PS. One of the best products! Thanks for your work!
I'm not sure what you ask me for. However if you need command-line SCP of SFTP client, I would recommend you PSCP and PSFTP from Putty package.
Andy M.
I meant this: command-line ssh + dual paneled browser. Anyone who uses Total Commander for local work, knows how useful it is to issue commands to OS, while browsing through directories.
Anyway, thanks for answer.
OK, now I understand, what you have meant. I'll consider it.
