Topic "Error 8: Maximum read size ( 32K ) has been exceeded."
ReactionWeb
This is a problem we were having w/ v 4.1.8, but still have w/ 4.2.2. It occurs in both gui and command line. It is a sFTP connection.
Basically, it's just a download of a file from the remote server. The error almost appears to come from the host, but I have made the same connection and transfer w/ FileZilla w/o an error.
I have searched both the fourms and Google, but have not found a solution. I hope you can help.
Initialised HMAC-SHA1 server->client MAC algorithm
Initialised zlib (RFC1950) decompression
Using username "crmftp".
Prompt (6, SSH password, , &Password: )
Using stored password.
Sent password
Access granted
Opened channel for session
Started a shell/command
Using SFTP protocol.
Doing startup conversation with host.
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 5, Number: -1
SFTP version 3 negotiated.
We believe the server has signed timestamps bug
We will use UTF-8 strings for status messages only
Changing directory to "/D:/MSL/PrivateMB/crmftpup/crmftpdown".
Getting real path for '/D:/MSL/PrivateMB/crmftpup/crmftpdown'
Type: SSH_FXP_REALPATH, Size: 52, Number: 16
Type: SSH_FXP_NAME, Size: 136, Number: 16
Real path is '/D:/MSL/PrivateMB/crmftpup/crmftpdown'
Trying to open directory "/D:/MSL/PrivateMB/crmftpup/crmftpdown".
Type: SSH_FXP_LSTAT, Size: 52, Number: 263
Type: SSH_FXP_ATTRS, Size: 37, Number: 263
Getting current directory name.
Listing directory "/D:/MSL/PrivateMB/crmftpup/crmftpdown".
Type: SSH_FXP_OPENDIR, Size: 52, Number: 523
Type: SSH_FXP_HANDLE, Size: 17, Number: 523
Type: SSH_FXP_READDIR, Size: 17, Number: 780
Type: SSH_FXP_NAME, Size: 138, Number: 780
Type: SSH_FXP_READDIR, Size: 17, Number: 1036
Type: SSH_FXP_NAME, Size: 140, Number: 1036
Type: SSH_FXP_READDIR, Size: 17, Number: 1292
Type: SSH_FXP_STATUS, Size: 55, Number: 1292
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 17, Number: 1540
Startup conversation with host finished.
File: "/D:/MSL/PrivateMB/crmftpup/crmftpdown/L_export1.csv"
Copying "/D:/MSL/PrivateMB/crmftpup/crmftpdown/L_export1.csv" to local directory started.
Binary transfer mode selected.
Checking existence of partially transfered file.
Asking user:
Target directory contains partially transfered file 'L_export1.csv'. Do you want to resume file transfer? Note: Answering 'No' would delete partially transfered file and restart transfer. ()
Opening remote file.
Type: SSH_FXP_OPEN, Size: 77, Number: 1795
Type: SSH_FXP_STATUS, Size: 52, Number: 1540
Discarding reserved response
Type: SSH_FXP_HANDLE, Size: 17, Number: 1795
Type: SSH_FXP_FSTAT, Size: 17, Number: 2056
Type: SSH_FXP_READ, Size: 29, Number: 2309
3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Type: SSH_FXP_ATTRS, Size: 37, Number: 2056
Storing reserved response
Status/error code: 8, Message: 4101, Server: The requested file can not be read. Maximum read size ( 32K ) has been exceeded., Language: en
18 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
Type: SSH_FXP_CLOSE, Size: 17, Number: 5124
(ECommand) Copying files from remote side failed.
The server does not support the operation.
Error code: 8
Error message from server (en): The requested file can not be read. Maximum read size ( 32K ) has been exceeded.
Request code: 5
What SFTP/SSH server are you using?
ReactionWeb
I'm told Momentum sFTP
I've sent you an email.
