Topic ""file already exists" on non-existant files"
Firewave
Since updating to 4.2.2 I am getting "file already exists" dialogs, although the file doesn't exist at all. It shows of size of 0 and a date in 1899.
It happens with a test system I am reinstalling very often (it's a VMware) with files I always copy to the /root folder after a fresh installation. Feels a bit like a caching issue to me.
I also had a problem, that a remote folder was treated like a symbolic link, which wasn't a link at all on that system, but on a different one I was accessing earlier.
Firewave
. 2009-07-03 11:16:58.562 --------------------------------------------------------------------------
. 2009-07-03 11:16:58.562 WinSCP Version 4.2.2 (Build 480) (OS 5.1.2600 Service Pack 3)
. 2009-07-03 11:16:58.562 Login time: Freitag, 3. Juli 2009 11:16:58
. 2009-07-03 11:16:58.562 Session name: root@192.168.56.150
. 2009-07-03 11:16:58.562 Host name: 192.168.56.150 (Port: 22)
. 2009-07-03 11:16:58.562 User name: root (Password: Yes, Key file: No)
. 2009-07-03 11:16:58.562 Tunnel: No
. 2009-07-03 11:16:58.562 Transfer Protocol: SFTP (SCP)
. 2009-07-03 11:16:58.562 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-07-03 11:16:58.562 Proxy: none
. 2009-07-03 11:16:58.562 SSH protocol version: 2; Compression: No
. 2009-07-03 11:16:58.562 Bypass authentication: No
. 2009-07-03 11:16:58.562 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-07-03 11:16:58.562 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-07-03 11:16:58.562 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-07-03 11:16:58.562 SFTP Bugs: -,-
. 2009-07-03 11:16:58.562 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-07-03 11:16:58.562 Shell: default, EOL: 0
. 2009-07-03 11:16:58.562 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-07-03 11:16:58.562 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-07-03 11:16:58.562 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-07-03 11:16:58.562 Cache directory changes: Yes, Permanent: Yes
. 2009-07-03 11:16:58.562 DST mode: 1
. 2009-07-03 11:16:58.593 Looking up host "192.168.56.150"
. 2009-07-03 11:16:58.593 Connecting to 192.168.56.150 port 22
. 2009-07-03 11:16:58.609 Server version: SSH-2.0-OpenSSH_4.2
. 2009-07-03 11:16:58.609 Using SSH protocol version 2
. 2009-07-03 11:16:58.609 We claim version: SSH-2.0-WinSCP_release_4.2.2
. 2009-07-03 11:16:58.609 Doing Diffie-Hellman group exchange
. 2009-07-03 11:16:58.609 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-07-03 11:16:58.843 Host key fingerprint is:
. 2009-07-03 11:16:58.843 ssh-rsa 1024 55:ab:52:40:27:65:49:5c:c6:dd:e8:6f:89:2c:82:2a
. 2009-07-03 11:16:58.843 Initialised AES-256 SDCTR client->server encryption
. 2009-07-03 11:16:58.843 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-07-03 11:16:58.843 Initialised AES-256 SDCTR server->client encryption
. 2009-07-03 11:16:58.843 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-07-03 11:16:58.843 Using username "root".
. 2009-07-03 11:16:58.859 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2009-07-03 11:16:58.859 Using stored password.
. 2009-07-03 11:16:59.046 Prompt (5, SSH server authentication, , <no prompt>)
. 2009-07-03 11:16:59.593 Access granted
. 2009-07-03 11:16:59.593 Opened channel for session
. 2009-07-03 11:16:59.609 Started a shell/command
. 2009-07-03 11:16:59.609 --------------------------------------------------------------------------
. 2009-07-03 11:16:59.609 Using SFTP protocol.
. 2009-07-03 11:16:59.609 Doing startup conversation with host.
> 2009-07-03 11:16:59.609 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-07-03 11:16:59.843 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-07-03 11:16:59.843 SFTP version 3 negotiated.
. 2009-07-03 11:16:59.843 We believe the server has signed timestamps bug
. 2009-07-03 11:16:59.843 We will use UTF-8 strings for status messages only
. 2009-07-03 11:16:59.843 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-07-03 11:16:59.843 Getting current directory name.
. 2009-07-03 11:16:59.843 Getting real path for '.'
> 2009-07-03 11:16:59.843 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-07-03 11:16:59.843 Type: SSH_FXP_NAME, Size: 31, Number: 16
. 2009-07-03 11:16:59.843 Real path is '/root'
. 2009-07-03 11:16:59.843 Listing directory "/root".
> 2009-07-03 11:16:59.843 Type: SSH_FXP_OPENDIR, Size: 14, Number: 267
< 2009-07-03 11:16:59.859 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2009-07-03 11:16:59.859 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2009-07-03 11:16:59.859 Type: SSH_FXP_NAME, Size: 3665, Number: 524
> 2009-07-03 11:16:59.859 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2009-07-03 11:16:59.859 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2009-07-03 11:16:59.859 Status/error code: 1
> 2009-07-03 11:16:59.859 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2009-07-03 11:16:59.859 Startup conversation with host finished.
. 2009-07-03 11:17:05.203 Copying 1 files/directories to remote directory "/root/"
. 2009-07-03 11:17:05.203 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2009-07-03 11:17:05.203 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-07-03 11:17:05.203 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-07-03 11:17:05.203 File: "D:\bin.gz"
. 2009-07-03 11:17:05.203 Copying "D:\bin.gz" to remote directory started.
. 2009-07-03 11:17:05.203 Binary transfer mode selected.
. 2009-07-03 11:17:05.203 Checking existence of file.
> 2009-07-03 11:17:05.203 Type: SSH_FXP_LSTAT, Size: 21, Number: 1287
< 2009-07-03 11:17:05.203 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2009-07-03 11:17:05.203 Discarding reserved response
< 2009-07-03 11:17:05.203 Type: SSH_FXP_STATUS, Size: 29, Number: 1287
< 2009-07-03 11:17:05.203 Status/error code: 2
. 2009-07-03 11:17:05.203 Checking existence of partially transfered file.
> 2009-07-03 11:17:05.203 Type: SSH_FXP_LSTAT, Size: 30, Number: 1543
< 2009-07-03 11:17:05.203 Type: SSH_FXP_STATUS, Size: 29, Number: 1543
. 2009-07-03 11:17:05.203 Asking user:
. 2009-07-03 11:17:05.203 Remote file 'bin.gz' already exists. Overwrite?
. 2009-07-03 11:17:05.203 New: 34180107 bytes, 01.07.2009 13:20:04
. 2009-07-03 11:17:05.203 Existing: 0 bytes, 30.12.1899 00:00:00 ()
. 2009-07-03 11:17:06.062 Opening remote file.
> 2009-07-03 11:17:06.062 Type: SSH_FXP_OPEN, Size: 46, Number: 1795
< 2009-07-03 11:17:06.062 Type: SSH_FXP_HANDLE, Size: 13, Number: 1795
> 2009-07-03 11:17:06.062 Type: SSH_FXP_WRITE, Size: 4121, Number: 2310
. 2009-07-03 11:17:48.703 2105 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-07-03 11:17:48.703 Type: SSH_FXP_CLOSE, Size: 13, Number: 272132
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 24, Number: 271622
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 24, Number: 271878
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 24, Number: 272132
< 2009-07-03 11:17:48.718 Status/error code: 0
> 2009-07-03 11:17:48.718 Type: SSH_FXP_RENAME, Size: 46, Number: 272402
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 24, Number: 272402
> 2009-07-03 11:17:48.718 Type: SSH_FXP_SETSTAT, Size: 33, Number: 2057
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 24, Number: 2057
. 2009-07-03 11:17:48.718 Listing directory "/root".
> 2009-07-03 11:17:48.718 Type: SSH_FXP_OPENDIR, Size: 14, Number: 272651
< 2009-07-03 11:17:48.718 Type: SSH_FXP_HANDLE, Size: 13, Number: 272651
> 2009-07-03 11:17:48.718 Type: SSH_FXP_READDIR, Size: 13, Number: 272908
< 2009-07-03 11:17:48.718 Type: SSH_FXP_NAME, Size: 3773, Number: 272908
> 2009-07-03 11:17:48.718 Type: SSH_FXP_READDIR, Size: 13, Number: 273164
< 2009-07-03 11:17:48.718 Type: SSH_FXP_STATUS, Size: 28, Number: 273164
< 2009-07-03 11:17:48.718 Status/error code: 1
> 2009-07-03 11:17:48.718 Type: SSH_FXP_CLOSE, Size: 13, Number: 273412
. 2009-07-03 11:17:50.265 Closing connection.
. 2009-07-03 11:17:50.265 Sending special code: 12
. 2009-07-03 11:17:50.265 Sent EOF message
This bug has been added to tracker.
Firewave
The issue is fixed for me in the debug build you sent me.
Thanks.
