Topic "Pass command-line parameters to script"
I'm trying to run this example script.tmp:
option batch on
open mysession
put %1%
...using the following example syntax: /script=script.tmp /parameter c:\myfile.txt
...and I get the error:
File or folder '%1%' does not exist.
What am I doing wrong?
The /parameter switch was introduced in 4.2.2 beta. I suspect you are using earlier version.
Yes, I was using 4.1.9 - I'll try the new beta.
