Topic "[fixed] WinSCP 4.2.x shows one more "empty" log-in prompt"
MT
Log-in process in 4.1.x:
- activate stored session (no password saved)
- server prompt appears (Password:)
- write password and hit Enter key to submit
- done, I'm logged in
Log-in process in 4.2.x:
- one more server prompt appears, no question, no prompt, just three buttons (OK, Cancel, Help)
- hit Enter key [OK button] to continue
Tested versions:
- 4.1.8: OK
- 4.1.9: OK
- 4.2.0 beta: bug
- 4.2.1 beta: bug
- 4.2.2 beta: bug
Detailed log (version 4.2.2, debug 2, prompt lines highlighted):
[log deleted]
Server information:
Session protocol = SSH-2
SSH implementation = OpenSSH_4.5
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-3
Server host key fingerprint
ssh-rsa 1024 63:63:cb:a0:4d:b0:2a:68:24:d9:8c:24:96:83:46:22
Can change permissions = Yes
Can change owner/group = No
Can execute arbitrary command = No
Can create symlink/hardlink = Yes/No
Can lookup user groups = No
Additional information
The server does not support any SFTP extension.
MT
Seems to be same as http://winscp.net/forum/viewtopic.php?t=6620 (I've searched through old bug records but have to miss it.)
If I understand http://winscp.net/tracker/show_bug.cgi?id=388 correctly, it's already fixed.
I'll wait for version 4.2.3.
Correct.
