Topic "UTF-8 support diferences SFTP and FTP"
havranek
I must use UTF-8 setting ON to SFTP connect to my UTF-8 linux (it's OK, protocol SFTP-3)
I must use UTF-8 setting OFF to FTP connect to same linux. Why?
(WinSCP 4.1.9/4.2.2.480, vsftpd-2.0.5-12.el5_3.1)
2.
With FTP protocol WinSCP with UTF-8 setting OFF I can see correct filenames with czech UTF-8 character and can use these files. But WinSCP also can see correct filenames saved icorrectly by another client in codepage windows-1250 on UTF-8 server and cannot use these files and directories.
Possibly your FTP server is not configured to use UTF.
What does it mean, "can see correct filenames with czech UTF-8 character". Do you see czech letters or do you their UTF equivalents?
If I have good information FTP protocol doesn't transfer information about codepage. Server is completly in UTF-8 (CentOS 5.3, vsftpd). Then I need set FTP client to use UTF-8 for filename coding. I must set WinSCP client diferently for FTP and for SFTP (UTF-8 for FTP off and for SFTP on). I don't understand why.
Yes. WinSCP sees czech letters in directory. If I have set UTF-8 off with FTP, I see
  • /files-from-utf-8-client/ěčř.txt
  • /files-from-win-1250-client/ěčř.txt - this file I cannot open or download
I I have set UTF-8 on with FTP, I see
  • /files-from-utf-8-client/욍ŞýáĂĂ.txt (can be downloaded)
The your FTP server probably converts UTF8 filenames to Windows 1250 on the wire.
I have no explanation for the other problem.
Havranek
With Total Commander it's O.K. With WinSCP it's not O.K. I think problem is not on my FTP server.
I can set my FTP login name and password for testing to your private e-mail.
OK.
ajay
hi guys,
I am trying to transfer files through sftp, when i try to do so
it does not work
and the file permission changed to "-r-Sr-----".... Please let me know what should be the directory permission where i am putting this file. please revert asap
ajay wrote:
hi guys,
it does not work
Please start new thread, this is out of topic.
