Topic "Can't install WinSCP 4.2.2 beta on Windows 2000"
joopbraak
When trying to install WinSCP 4.2.2 beta on Windows 2000, I get the error message:
Runtime Error (at -1:0)
Cannot Import dll:C:\WINNT\TEMP\is-XXXXX.tmp\OCSetupHlp.dll.
The XXXXX is randomly generated.
I know it has to do with the new OpenCandy part of the installer.
Two questions:
- When will this be solved?
- Are you planning to become adware?
joopbraak
I know a workaround already for this problem.
Take psapi.dll from a XP computer (or download it from http://www.dlldump.com/dllfiles/P/psapi.dll) and put it in the same directory as the installer.
This bug has been added to tracker. Going to fix in in the next release.
I've tried to answer this in documentation.
joopbraak
Thanks!
If you need to do this to continue development of this great program, I can't complain about it. Keep up the good work.
