Topic "Can't login using WinSCP"
fool
Hi
Every time I try to log into an ssh-server, I get:
"Network Error: Connection refused"
I am using v4.22 and have previously tried and failed with 4.19
I have tried disabling my firewall and there should not be any proxies in the way. I am running WinXP Home SP3 and the point is:
I can log in perfectly well using PUTTY, however not at all using WinSCP.
Thanks for any help!
Please post a log file both from PuTTY and WinSCP.
fool
. 2009-07-15 21:14:05.765 --------------------------------------------------------------------------
. 2009-07-15 21:14:05.765 WinSCP Version 4.2.2 (Build 480) (OS 5.1.2600 Service Pack 3, v.3264)
. 2009-07-15 21:14:05.765 Login time: Mittwoch, 15. Juli 2009 21:14:05
. 2009-07-15 21:14:05.765 Session name: ***
. 2009-07-15 21:14:05.765 Host name: *** (Port: 22)
. 2009-07-15 21:14:05.765 User name: *** (Password: Yes, Key file: No)
. 2009-07-15 21:14:05.765 Tunnel: No
. 2009-07-15 21:14:05.765 Transfer Protocol: SFTP (SCP)
. 2009-07-15 21:14:05.765 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-07-15 21:14:05.765 Proxy: none
. 2009-07-15 21:14:05.765 SSH protocol version: 2; Compression: No
. 2009-07-15 21:14:05.765 Bypass authentication: No
. 2009-07-15 21:14:05.765 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-07-15 21:14:05.765 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-07-15 21:14:05.765 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-07-15 21:14:05.765 SFTP Bugs: -,-
. 2009-07-15 21:14:05.765 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-07-15 21:14:05.765 Shell: default, EOL: 0
. 2009-07-15 21:14:05.765 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-07-15 21:14:05.765 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-07-15 21:14:05.765 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-07-15 21:14:05.765 Cache directory changes: Yes, Permanent: Yes
. 2009-07-15 21:14:05.765 DST mode: 1
. 2009-07-15 21:14:05.843 Looking up host "***"
. 2009-07-15 21:14:05.859 Connecting to *** port 22
. 2009-07-15 21:14:07.265 Failed to connect to ***: Network error: Connection refused
* 2009-07-15 21:14:07.265 (ESshFatal) Network error: Connection refused.
this is the winSCP log file
how can I create a log file with putty? is there a manual sw?
See logging tab of PuTTY login dialog. Select "All session output" and choose file.
Anyway you have removed important infomation from the WinSCP log file. As it is, it is useless for me. If you do not want to post it in clear here, you can send the logs to my by an email.
