Topic "redirection via the winscp.exe"
winscp.exe does everything I need for automation, except for output redirection of the LS command. In the forum I see that output direction can only be done by winscp.com. So, could redirection be added to winscp.exe? Or could a redirection option be added to the LS command, like the following?
ls *.* /Redirect=C:\DirectoryList.txt
Thanks, Scott
PS Alternately, if it is not possible to add output redirection for the LS command to the winscp.exe, could the winscp.com file be added standalone next to the download of the winscp.exe command so that the full install would not need to be done to get the winscp.com file? Thanks, Scott
No, Windows do not allow that.
Use XML logging instead.
Thanks, Martin. I'll check in to the XML logging. - Scott
