Topic "Where is session configuation saved?"
jefe
I would like to use a common session on my desktop and laptop machines. I've looked but I can't find where specific session preferences are saved. If I can locate where session configuration files are stored, I'll just transfer them between machines
Where are they hiding? Confused
tia
jefe
Disregard.
After poking around in options some more I found the option to save to an .ini file, which I did. I then simply copied the .ini file from one machine to another.
Please read documentation.
