Error creating temporary file due to illegal characters
sc911
Hello *,
when trying to edit a file on a server (Explorer-Interface: right-click on file, select Edit), it fails with the following message:
Cannot create temporary directory 'C:\DOKUME~1\xxx\LOKALE~1\Temp\scp59343\...\xxx\'. You may change root directory to store temporary files in Preferences.
The file to edit is located on the server at
/.../xxx/file.txt
(Replaced some strings with xxx for shortening and privacy)
The problem here is, that no a directory with the name ... (only dots, no letters or numbers) is not allowed in the windows filesystem and so the creation of the directory fails.
There should be a substitution of those illegal characters when temporary saving those files.
Thanks for this great program!
Regards
sc911
WinSCP 4.1.9 (Build 416)
Windows XP Professional SP3 German
Connectiontype: SFTP-3
