Topic "Empty Folder (LIST -a) (4.2.2 (Build 480)"
rgbgerman
hi,
it seems to me, that the LIST command failes. other ftp programs do not have any problems with the ftp server.
winscp only shows me an empty directory. as i can see at the log, i think its because of the "LIST" command.
 2009-07-24 11:30:11.101 Connecting to 85.25.xx.xx ...
. 2009-07-24 11:30:11.555 Connected with 85.25.xx.xx. Waiting for welcome message...
< 2009-07-24 11:30:12.065 220 Personal FTP Server ready.
> 2009-07-24 11:30:12.065 USER xxxxx
< 2009-07-24 11:30:12.573 331 Password required for xxxxx.
> 2009-07-24 11:30:12.573 PASS *******
< 2009-07-24 11:30:13.063 230 User xxxxx logged in.
> 2009-07-24 11:30:13.063 SYST
< 2009-07-24 11:30:13.587 215 UNIX Type: Personal FTP Server PRO K6.0
> 2009-07-24 11:30:13.587 FEAT
< 2009-07-24 11:30:14.116 211-Extensions supported:
< 2009-07-24 11:30:14.116   SIZE
< 2009-07-24 11:30:14.116   REST STREAM
< 2009-07-24 11:30:14.116   MDTM
< 2009-07-24 11:30:14.116   MDTM YYYYMMDDHHMMSS[+-TZ] filename
< 2009-07-24 11:30:14.116   MLST size*;type*;perm*;create*;modify*;
< 2009-07-24 11:30:14.116   MFMT
< 2009-07-24 11:30:14.116   MD5
< 2009-07-24 11:30:14.116 211 END
. 2009-07-24 11:30:14.118 Connected
. 2009-07-24 11:30:14.118 Got reply 1 to the command 1
. 2009-07-24 11:30:14.118 --------------------------------------------------------------------------
. 2009-07-24 11:30:14.118 Using FTP protocol.
. 2009-07-24 11:30:14.118 Doing startup conversation with host.
> 2009-07-24 11:30:14.120 PWD
< 2009-07-24 11:30:14.651 257 "/d:/box/xxxxx/out/" is current directory.
. 2009-07-24 11:30:14.651 Got reply 1 to the command 16
. 2009-07-24 11:30:14.654 Getting current directory name.
. 2009-07-24 11:30:14.657 Retrieving directory listing...
> 2009-07-24 11:30:14.657 TYPE A
< 2009-07-24 11:30:15.188 200 Type set to A.
> 2009-07-24 11:30:15.189 PASV
< 2009-07-24 11:30:15.699 227 Entering Passive Mode (85,xx,xx,xx,7,208).
> 2009-07-24 11:30:15.699 LIST -a
< 2009-07-24 11:30:16.223 150 Opening data connection for directory list.
. 2009-07-24 11:30:16.834 d:\box\xxxxx\out\-a not found
< 2009-07-24 11:30:17.331 226 File sent ok
. 2009-07-24 11:30:17.332 Directory listing successful
. 2009-07-24 11:30:17.332 Got reply 1 to the command 2
. 2009-07-24 11:30:17.332 Startup conversation with host finished.
. 2009-07-24 11:30:18.130 Session upkeep
. 2009-07-24 11:30:18.644 Session upkeep
. 2009-07-24 11:30:19.159 Session upkeep
. 2009-07-24 11:30:19.658 Session upkeep
. 2009-07-24 11:30:20.173 Session upkeep
d:\box\xxxxx\out\-a not found seems to be the error....
is there anything i can do ?
thank you,
micha
