Topic "XML Parse - WINSCP"
Jappie
Hey All,
Got a question about the XML logging and how to parse these to readable text
This is for example my output: test.xml
<session xmlns="http://winscp.net/schema/session/1.0" name="test@127.0.0.1" start="2009-07-24T09:30:19.531Z">
<download>
<filename value="/\test\/test_script.txt" />
<destination value="c:\test\test_script.txt" />
<result success="true" />
</download>
</session>
Here is my XML parser i use: xml_parser.html
<html>
<body>
<script type="text/javascript">
try //Internet Explorer
xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
catch(e)
try //Firefox, Mozilla, Opera, etc.
xmlDoc=document.implementation.createDocument("","",null);
catch(e) {alert(e.message)}
try
xmlDoc.async=false;
xmlDoc.load("test.xml");
document.write("xmlDoc is loaded, ready for use");
document.write("<table border='1'>");
var x=xmlDoc.getElementsByTagName("download");
for (i=0;i<x.length;i++)
document.write("<tr><td>");
document.write(x[i].getElementsByTagName("filename")[0].childNodes[0].nodeValue);
document.write("</td><td>");
document.write(x[i].getElementsByTagName("result")[0].childNodes[0].nodeValue);
document.write("</td></tr>");
document.write("</table>");
</script>
</body>
</html>
This is not gonna work because the xml_parse.html expects a </filename> and a </result> If i edit the xml file with this it works....
How can i fix this ?
And how can i see after parse only the false results what's in my test.xml ?
So the value result is false and not true.
Thanks in advance,
Jappie
WinSCP version: 2.2.0.105
OS: Win XP Sp3
I do not know JavaScript enough to know what's wrong about your code. Though there's nothing wrong about the XML. <filename></filename> and <filename /> are equivalent in XML.
Please see guide to advanced scripting for example for to use XPath to retrieve information from XML.
Jappie
Thnx for response, i tried the Xpath, but dunno exactly how this works with the XML log. I got it working but it's the same as my first post.
See http://www.w3schools.com/XPath/xpath_examples.asp what i did.
Can you give the right commands for Parsing my example ?
//w:download/w:filename/@value
//w:download/w:result[@success='false']
I haven't tried them though.
Jappie
Hmmm, understand what you mean, but can't translate it at the moment to get it work in my example....
Can't find either the log.xml you are using with youre guide to advanced scripting, where can i download it so i can try it on mine and then edit it with youre code you give me.
It's not available for download. It is just an example.
Jappie
ok....then i think i'm stuck.....
