Topic "550 Can't remove directory: No such file or directory"
mattyc
Using WinSCP 4.1.9 connecting via ftp
It appears to only be a problem with fasthosts servers - I have a dedicated server running CentOS 5.3
I can't delete folders (full or empty). I know it's a problem with WinSCP as I can delete the same folders fine using Dreamweavers ftp unctionality.
ftp log:
Creating directory "test".
CWD /user/htdocs/
250 OK. Current directory is /user/htdocs
MKD test
257 "test" : The directory was successfully created
Retrieving directory listing...
TYPE A
200 TYPE is now ASCII
PORT 192,168,100,60,8,61
200 PORT command successful
LIST -a
150 Connecting to port 5017
226-Options: -a -l
226 7 matches total
Directory listing successful
Deleting file "test".
CWD /user/htdocs/test/
250 OK. Current directory is /user/htdocs/test
PWD
257 "/user/htdocs/test" is your current location
TYPE A
PORT 192,168,100,60,8,63
LIST -a
150 Connecting to port 5018
226-Options: -a -l
226 2 matches total
Synchronizing current directory "/user/htdocs".
CWD /user/htdocs
RMD /user/htdocs/test/
Asking user:
Error deleting file 'test'. ("Can't remove directory: No such file or directory")
If i now connect with dreamweaver using same login details I can delete the folder fine!
Please help.
I can delete files fine:
Deleting file "test.html".
DELE /user/htdocs/test.html
250 Deleted /user/htdocs/test.html
CWD /user/htdocs/
PWD
257 "/user/htdocs" is your current location
TYPE A
PORT 192,168,100,60,8,138
LIST -a
150 Connecting to port 5027
226-Options: -a -l
226 6 matches total
Can you post a log file showing Dreamweaver deleting the directory? I.e. the same task shown in WinSCP log.
mattyc
Hi Martin
No problem. Here is exactly the dreamweaver ftp log for exactly the same proccess on the same server, the only slight difference being that from the looks of it dreamweaver creates a directory called untitled when you right click/add new folder, then it gets renamed to testwhen I type in the name i want it to be.
< 250 OK. Current directory is /user/htdocs
> MKD untitled
< 257 "untitled" : The directory was successfully created
> CWD /user/htdocs/untitled
< 250 OK. Current directory is /user/htdocs/untitled
> PWD
< 257 "/user/htdocs/untitled" is your current location
> PASV
< 227 Entering Passive Mode (88,208,218,95,217,127).
> TYPE A
< 200 TYPE is now ASCII
> LIST
< 150 Accepted data connection
< 226-Options: -l
< 226 0 matches total
> CWD /user/htdocs
> RNFR untitled
< 350 RNFR accepted - file exists, ready for destination
> RNTO test
< 250 File successfully renamed or moved
< 250 OK. Current directory is /user/htdocs/test
> PWD
< 257 "/user/htdocs/test" is your current location
> PASV
< 227 Entering Passive Mode (88,208,218,95,216,217).
> TYPE A
> LIST
< 226-Options: -l
> CWD /user/htdocs
> RMD test
< 250 The directory was successfully removed
Server details :
CentOS 5.3
Fasthosts CentOS 5 dedicated servers deliver:
* Kernel 2.6
* Apache 2.2 web server
* PureFTP FTP server
* Courier POP and IMAP mail server
* Postfix SMTP mail transit agent
* MySQL database management system
* Bind 9.3 DNS
* Perl, Python and PHP scripting
* IPTables firewall security
* NTP automatic time synchronisation
* nightly updates.
mattyc
Also it's interesting to note that WinSCP can rename folders fine so I guess it can't be a permissions problem:
CWD /user/htdocs/
MKD test
TYPE A
PASV
227 Entering Passive Mode (88,208,218,95,68,133).
LIST -a
226-Options: -a -l
226 11 matches total
Renaming file "test" to "test2".
RNFR /user/htdocs/test
RNTO /user/htdocs/test2
TYPE A
PASV
227 Entering Passive Mode (88,208,218,95,163,228).
LIST -a
226-Options: -a -l
Deleting file "test2".
CWD /user/htdocs/test2/
250 OK. Current directory is /user/htdocs/test2
PWD
257 "/user/htdocs/test2" is your current location
TYPE A
PASV
227 Entering Passive Mode (88,208,218,95,7,140).
LIST -a
226-Options: -a -l
226 2 matches total
CWD /user/htdocs
RMD /user/htdocs/test2/
Asking user:
Error deleting file 'test2'. ("Can't remove directory: No such file or directory")
davidfernando
I think that it was fixed in 4.0.6.
mattyc
I am running 4.1.9 (Build 416)
Possibly your server has problems with delete syntax WinSCP is using:
Problem can be either full path or slash at the end.
Can you please try to manually delete a subdirectory of current working directory using following commands to see which one works?
RMD test
RMD test/
mattyc
Hi Martin
You are right. I tried all your commands via the WinSCP command line
RMD test
RMD test/
both work, where as
Doesn't. The server is a box standard CentOS 5.3 with PureFTP. In fact the entire operating system was rebuilt last week (but the same thing happened before this).
Is there any fix as I really like WinWCP!
Well I believe it is perfectly valid to specify full path in delete command. So it should rather be fixed on server-side.
Though this issue has been added to tracker anyway.
mattyc
Hi
I just tried a few other ftp clients (including fileZilla, and even windows bult in ftp!) and all work fine. Here is the log from filezilla
Command: MKD test
Response: 257 "test" : The directory was successfully created
Status: Retrieving directory listing...
Command: PASV
Response: 227 Entering Passive Mode (88,208,218,95,188,169).
Command: MLSD
Response: 150 Accepted data connection
Response: 226-ASCII
Response: 226-Options: -l
Response: 226 35 matches total
Status: Directory listing successful
Command: CWD test
Response: 250 OK. Current directory is /user/htdocs/test
Command: PWD
Response: 257 "/user/htdocs/test" is your current location
Command: PASV
Response: 227 Entering Passive Mode (88,208,218,95,41,36).
Command: MLSD
Response: 226-ASCII
Response: 226 0 matches total
Command: CWD /user/htdocs
Command: PWD
Response: 257 "/user/htdocs" is your current location
Command: RMD test
Response: 250 The directory was successfully removed
Hopefully something can be done to fix WinWSCP as so far the interface for all other ftp clients I have looked at are terrible, but if it can't delete directories then it's not much use to me Sad
Thanks for looking into it anyway.
Matt
mattyc
p.s. I noticed you have described the bug in tracker as 'Some servers fail to delete directory when full...', but it has nothing todo with the directory being full... it doesn't delete empty directories either.
It says nothing about directory being full. It says that your server does not allow full path (/user/htdocs/test, as opposite to just text) after RMD command.
Demented
i cant seem to delete this folder
from my server i keep getting this error message every time and i am running winscp v4.19
The Boxer From Shantung/: No such file or directory
vayana
I know this is now a couple years later, but i just had the same issue with winscp. I had accidentally renamed a file to .bak\ and the file explorer in winscp showed only .bak Therefor I was unable to rename/download/delete the file and it kept saying no such file.
After reading this thread I downloaded filezilla, which showed the full name, and it allowed me to rename the file.
