Topic "synchronise folder"
jai.venkat
Hello
I have two folders that i want to synchronise.
option batch on
open username:password@host:2202
cd advert/area1
lcd d:\advert\area1
synchronize local -criteria=size
Even though contents of d:\advert\area1 is empty message keeps stating that "Nothing to sychronize"
Any ideas how i can resolve, thanks.
Look forward to any replies
regards
jai
Also please post a full log file showing the problem.
