Topic "Log only output of synchronization job"
WouterT
Hi all,
Is it possible to only log the output of the sync command.
I'm running:
synchronize REMOTE -mirror -delete "c:\temp" /home/wouter/Temp
And I only want the output of this command stored in a log file, so I can use it again in an email script.
So I only want to know what's been modified (del/copy etc) in the transfer, below is the part I need.
Comparing...
Local 'c:\temp\2' => Remote '/home/wouter/Temp/2'
Synchronizing...
Local 'c:\temp' => Remote '/home/wouter/Temp'
'/home/wouter/Temp/log.txt' deleted
winscp>
The /log with winscp.exe gives me way to much info.
Anyone who can point me in the right direction.
Thanks!
Wouter
Use XML logging.
WouterT
prikryl wrote:
Thanks for the reply, I'll look into the xml logging.
thibeau
hi, looking to do the same thing, just so I don't have to re-invent the wheel can you post your solution?
