OpenCandy
OpenCandy
If I use just the executable, and not the installation package, will I EVER have to worry about Opencandy being installed? I ask because i use this software at work, and cannot use software that would be considered adware/spyware, which opencandy is.
kind regards,
Bryan
Re: OpenCandy
No. OpenCandy is used in installer only. See documentation.
