Topic "Failing to overwrite remote file when of zero size"
drmrbrewer
There have been a few times recently when my ftp connection has seemingly dropped, causing some remote files to have size zero. When I subsequently drag a bunch of local files onto the remote folder (including the file having non-zero local size but zero remote size), and click New and Updated Files Only (which I usually do, in order to update only those files that have changed), the affected file is not overwritten. This is despite the local (non zero size) file having a newer date and a different size.
Using beta 4.2.2 480
Mike
Can you post a screenshot of local and remote file panels showing the affects files?
