Topic "Winscp password change"
roy4magic
Hi, sorry after an hour I cannot find how to change it - I don't get the window you show in your FAQ which enables change. I'm on Vista with iPhone - it logs in OK. Thank you.
Sorry I do not understand. What password do you want to change? That FAQ do you refer to?
johnbmwx6
I have the same problem, I can log in but Putty.exe command is not there!!!, any ideas.
download it from http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
then place the *.exe into the right directory
Hiro4476
forgot the mention,
think the default directory is "C:\Program Files\PuTTY"
johnbmwx6
Thanks Guys will give it a go. Smile
johnbmwx6
I put the file into WinSCP/puTTy, and nothing happened, same "No puTTY.exe"
I tried openning the file and it wanted to made a key!!
I refused to save it, could this be the problem, It also openned a BLACK systems box with the prompt in it!! again I closed this not knowing what to do!!.
Ideas please.
Hiro4476
do you mean you put the *.exe under "..\WinSCP\puTTy\"?
like I said, the default dir is "C:\Program Files\PuTTY"
so it'll become like "C:\Program Files\PuTTY\putty.exe"
unless you go into the setting and change it.
I downloaded the files and put the package in the file group under PuTTy.
I tried to open the file and the Winscp screen came up, so tried to access through this and again failed with the message "NO PuTTY.exe", stumped Confused
johnbmwx6
I am not getting anywhere with this, I downloaded Putty exe file, put it in the Putty file group. Nothing gained still says NO exe command.
I tried openning it and it openned as the Log-in box, which then openned the terminal (black
)promp box!!
Help please. Confused
Khyster
I've changed my user name and password between my iphone and pc and get an error "network connection refused. Can I pls get this reset. Please email to Khytheria@gmail.com
