Topic "automatic sftp to cygwin but key not accepted"
clasha
Hi, I have setup cygwin and am able to connect via WinScp using u/n and p/w. I saved the key when it prompted me the first time. I wanted to automate this login using a public key. I tried copying the key from /.ssh folder over to the client Windows PC and try to generate a key that WinSCP can recognize. I point it to the converted key and when I try to connect, cygwin refuses the key. u/n and p/w still works for manual connection.
Thoughts?
You confuse client and server key. There's are different.
clasha
Hi, I have looked through documentation but not sure what I am missing. Once a public key is generated on the server, I should only have to copy that onto the client and tell it to use that public key when connecting so it don't prompt for password?? WinSCP did not see the key in its default format as generated by cygwin so I had to use the tools to convert it to a recognized file format. What am I missing? I am new to this so please bare with me.
