Topic "COM or ActiveX component"
chrwei
wrap up the basic functions in a COM component so they can used from other apps.
Benifits to you:
- would allow someone that knows how to integrate into explore or map a drive make an app to do it without having to first decipher winSCP
- would allow reuse in automated applications, like a offline sync, so it's done without user interaction on a schedual
- would satisfy all these poeple wanting a different interface by allowing them to make one in VB or Delphi.
- would get you tons of chicks cause reuable components are cool!
I was already thinking about this. I'll think more Smile
veeru
Dear Sir,
Due you have activex component for WinScp so that it can be used for visual Baic 6.0.
regards
Veerprakash
No. But you can use scripting.
