Topic "WinSCP, SFTP, ASP.NET, downloading file to memorystream?"
alasaadi
Dear all,
I have a script in my ASP.NET page that gets a PDF file through FTP channel and puts it in a memorystream and then output it for the user.
this script looks like this:
Const username As String = "user"
Const password As String = "password"
Dim URI As String = "ftp://192.168.10.10/" & filename
Dim request2 As FtpWebRequest = DirectCast(FtpWebRequest.Create(URI), FtpWebRequest)
request2.Credentials = New System.Net.NetworkCredential(username, password)
request2.Method = WebRequestMethods.Ftp.DownloadFile
Dim response2 As FtpWebResponse = DirectCast(request2.GetResponse(), FtpWebResponse)
Dim responseStream As IO.Stream = response2.GetResponseStream()
Dim reader As New IO.StreamReader(responseStream)
Dim buffer As [Byte]() = New [Byte](2046) {}
Dim memstream As New IO.MemoryStream
Dim read As Integer = 0
Do
read = responseStream.Read(buffer, 0, buffer.Length)
'responseStream.Write(buffer, 0, read)
memstream.Write(buffer, 0, read)
Loop While read <> 0
Response.AddHeader("Content-Disposition", "inline; filename=" + filename)
Response.ContentType = "Application/pdf"
Response.BinaryWrite(memstream.ToArray)
Response.Flush()
Response.End()
responseStream.Close()
memstream.Flush()
memstream.Close()
Now, i want to switch to SFTP and I am using WinSCP. I managed to get the link ready, however, i am still struggling with the way to download the PDF file to a memorystream and then output it for the user.
Can you please help me to apply SFTP using WinSCP on the above script?
Thanks in advance.
I'm sorry, but you cannot do this with WinSCP. You have to download it to temporary file.
alasaadi
Sad that's sad.. but thanks for the response.
ephraimdov
string memString = "Memory test string !!";
// convert string to stream
byte[] buffer = Encoding.ASCII.GetBytes(memString);
MemoryStream ms = new MemoryStream(buffer);
//write to file
FileStream file = new FileStream("d:\\file.txt", FileMode.Create, FileAccess.Write);
ms.WriteTo(file);
Source : MemoryStream to File
Dov
