Topic "Cannot download remote file A call to an OS function failed"
angelyssa
hello, i have the latest version of WinSCP, and am connecting to a server via SCP protocol.
I have all the files locally on my hard drive, but when I attempt to download the same
files from Remote server, I get the following error:
It is happening on 2 of my computers, with same setup.
Can someone let me know if there is some setting i need to change to make this work?
Even if I delete the local file, copy the remote file, and then attempt to copy that same
remote file to overwrite the local version, I get the same message.
File permission on Remote server is r-r-r.
Thanks!
