external file with connection settings
cniry
hi,
how can I add my connections to taskbar of windows 7?
I create file "spojeni.scp", what I have asigned to opening in winSCP but when I tried to run it, winSCP say: Host not found.
spojeni.scp contain:
option batch on
open ftp://user:pass@multihost.cz
I know, that it can be opened in command line with winscp.exe /console /script=example.txt
But when I assigned file to opening in winscp, i think that Windows call it as: winscp.exe spojeni.scp
Thanks very much for reply. Sorry for my bad english :)
cniry
Re: external file with connection settings
At windows registry I edit key
HKEY_CLASSES_ROOT\Applications\WinSCP.exe\shell\open\command
"C:\Program Files\WinSCP\WinSCP.exe" /script="%1"
But it's doing nothink :(
for test i edit key as:
"C:\Program Files\WinSCP\WinSCP.com" /script="%1"
and this work fine, but only in console
It should do something, but hidden. Make sure to add /console switch to make the console visible.
