Topic "How can i get the Error Message?"
Many
I want to get an error message in vb.net, when i as example are not logged or have the wrong password. how can i get that? is that possible?
here is my code.
    ' New ProcessStartInfo created
            Dim p As New ProcessStartInfo
            'Specify the location of the binary
            p.FileName = Application.StartupPath & "\WinSCP.com"
            ' Use these arguments for the process
            p.Arguments = "/command ""option batch on"" ""Option Confirm Off"" ""open " & user & ":" & pw & "@" & adress & """" & remoteDir & " ""Option transfer binary"" ""Get " & remotePattern & " " & localDir & "*"" ""close"" ""exit"""
            'Use a hidden window
            p.WindowStyle = ProcessWindowStyle.Hidden
            ' Start the process
            Dim process1 As Process = Process.Start(p)
            'Dim output As String = process1.StandardOutput.ReadToEnd()
            'warten bis der Process beendet wird.
            process1.WaitForExit()
Many
ok, this is my solution. Laughing
            ' Run hidden WinSCP process
            Dim winscp As Process = New Process()
            winscp.StartInfo.FileName = "winscp.com"
            winscp.StartInfo.Arguments = "/command ""option batch on"" ""Option Confirm Off"" ""open " & user & ":" & pw & "@" & adress & """" & remoteDir & " ""Option transfer binary"" ""Get " & remotePattern & " " & localDir & "*"" ""close"" ""exit"""
            winscp.StartInfo.UseShellExecute = False
            winscp.StartInfo.RedirectStandardInput = True
            winscp.StartInfo.RedirectStandardOutput = True
            winscp.StartInfo.CreateNoWindow = True
            winscp.Start()
            ' Wait until WinSCP finishes
            winscp.WaitForExit()
            'Falls Anmeldungsfehler (z.b. Host nicht gefunden oder Passwort nicht korrekt)
            If winscp.ExitCode <> 0 Then
                ' Collect all output (not used in this example)
                'Hier werden die Erfolgs oder Errormeldungen ausgegeben.
                Dim errorOutput As String = winscp.StandardOutput.ReadToEnd()
                usefulFunctions.logMessage(errorOutput, "ERROR", "downloader.SFTP")
                Return False
            End If
