Topic "Transfer file from server to server"
Hi, I tried many times. It just not working. When I use put command, it will list the files needed to transfer, then just hang there.
I am basically wanting to transfer files from first server to second server in remote location, where both are windows server 2008.
When I close the hanged dos, the debug message return below
Error: -1073741510
I tried before, transfer from my local xp to remote server, no problem at all. But when I put the script into remote server, in order to server1 transfer to server2, it hang at put command.
Please note: I use ftp://...
I am not using sftp://
Please post a full log file showing the problem as well as your script.
