Topic "Rename bash script help"
i try to run the script below at WINSCP but it prompt out unknown command
Some1 can help me change the script which compatible with WINSCP and with same result?
for file in Stat_file*.txt; do
  mv "$file" "CUPT${file#Stat_file}"
done
thanks
If that is valid shell command, you need to use "call" command to execute it and reformat it to a single line.
