Topic "Noobie to WinSCP - Delete after Sync help plz."
munkdogg
Thus far my experience with WinSCP is about 3 days.
Thanks in large part to the examples & content on this site (which are superb), I have composed the following script to synchronize the contents of a remote dir with the local dir;
option batch on
open username:password@sftp.site.com
cd /remotedir
option transfer binary
synchronize local -delete
synchronize local c:\localdir /remotedir
close
It would seem the files are being synchronize w/o any issue, but the contents of the remote dir are not being deleted.
Is there something I have missed in using this condition in my script?
[/code]
I guess you expect your script to delete whole remote directory after synchronizing. It does not do that. The -delete switch tells it to delete whatever files are not present in the opposite directory.
If you want to delete the remote directory, do it explicitly with rmdir command.
Pritesh Davda
"synchronize local -delete" command is not deleting files in remote folder Sad
Keepuptodate is quite good solution but it runs as a service and I prefer to run job once or twice a day.
Any advise on why "synchronize local -delete" command is not working?
The command by definition removes file in local directory only. Please read documentation. If that does not help, come back.
I have added topic on deleting files after synchronization to FAQ.
JeffDallas
I am trying to pull files from a remote location to a local location and delete the sources files on success.
We are running this at a .bat.
winscp.exe /console /command
"open FTPLogin"
"synchronize local -delete -filemask="*.zip" "
"\\target\location\"
" /sourceLocation"
"close"
"exit"
The files transfer just fine, but the source files remain. I think I'm missing one little thing but after digging around the forums I haven't been able to get it to work.
This is exactly what the FAQ I've linked in my post above yours answers.
So once again:
http://winscp.net/eng/docs/faq_delete_synchronized_files
maiza
I am pretty new to scripting in general, and I did not want to create another topic when I believe what I am trying to do is very similar.
I have attempted to write a script that will synchronize a local folder with a remote folder. After the synchronization, the files in the local folder should be deleted.
Here is what I wrote:
open ftpsession
synchronize remote -nopreservetime
synchronize remote -nopermissions
synchronize remote "C:\Users\Local\Directory" "/remote/directory"
synchronize remote -delete
It is transferring the text files, but it is still giving me a permissions/preserve timestamp error for most of the runs I do. Also, none of the files in the local directory are being deleted afterwards.
I apologize for my inexperience. Any help would be appreciated.
It synchronizes, but generates a fi
You need to use a single synchronize command, like:
synchronize remote -nopreservetime -nopermissions -delte "C:\Users\Local\Directory" "/remote/directory"
See examples:
http://winscp.net/eng/docs/scriptcommand_synchronize
tlw3
This is the solution I implemented:
In my batch file, I call WinSCP twice, invoking two different scripts.
The first script does my local sync:
synchronize local -filemask="*.*"
Then, in my batch file, I *move* those files to a permanent location, outside of the current hierarchy.
Now I invoke the second script which does a REMOTE synch with the delete option:
synchronize remote -delete -filemask="*.*"
Now I have all of my files with directory structure in tact, and the server has been properly cleaned.
My batch file looks something like this (simplified):
winscp.com /console /script="synch.scr"
robocopy "tempdir" "finaldir" /MOVE /E
winscp.com /console /script="cleanup.scr"
Can you copy and paste your batch file in its complete form? i'm a little confused
tunilove
it seams i click somewhere by mistake and i got server file deleted how i get them back
See https://winscp.net/eng/docs/faq_undelete
