How to upload exe, and other filles like wav files.
Trekky
Hi i need some help i want to upload wav files and exe files but when ever i drag the file in the transfer window appears but in the server directory nothing appears after the transfer window closes. help please
Re: How to upload exe, and other filles like wav files.
